- Nov 14, 2016
- 3,314
In your last photo there is a square at about the mid point that looks like it might have once been the home to an ID plate. I have a little Diamond H mill about this size, the brand is cast into the base and it has metal plates on the side of the head (?). Without the base or those plates I don't think there is anything that would identify the maker of mine either.
Mine has a power feed that runs off the pulley, just a rod with U joints. I've seen other small mills like this that use a similar power feed, so it might be something you could adapt or even make if you wanted to add power feed to yours.
Neat little mill and it looks like it is in pretty decent shape except for the missing bits.
