You don't need it ! That 8" Buck will bolt directly to the RT . 4 bolts and 4 T slot blocks . If you would want to use the chuck alone on your BP table you could use the plate . It's something handy to have .
Yeah I also ordered that 6” Vertex 3-jaw that I posted earlier in the thread because I have no willpower, LOL. I figure I’ll need to either buy the aluminum plate linked to earlier by Will or make one if I don’t want to use aluminum.
Doesn't matter if you have will power. I have plenty of Will power & many times it does me no good. I'm sitting here looking at 4 Amazon packages that just arrived. 3 arrived yesterday from Amazon. Bought stuff from HF yesterday & this morning, along with two Mikwaukee items I got from HD today too.
But to answer your question, it doesn't need to be thicker. My back plates are 3/4" thick but not including the register/boss for the chuck. I believe mine start out as 1" thick but again doesn't need to be.
Doesn't matter if you have will power. I have plenty of Will power & many times it does me no good. I'm sitting here looking at 4 Amazon packages that just arrived. 3 arrived yesterday from Amazon. Bought stuff from HF yesterday & this morning, along with two Mikwaukee items I got from HD depot today too.
So let me ask you this…would you prefer to go with aluminum, cast iron, or steel for the backing plate as I believe I’ve located pieces of all 3 materials that work size wise.
Either or . I used Aluminum jig plate to keep things light . ( and I had it in the basement )
Edit . This is just a plate for bolting to the BP .......not a back plate !
Definitely not alumn unless you had no other choice. I would choose cast iron as it's the most ideal for a chuck back plate but steel would be perfectly fine for a RT. Far less messy to machine to than CI. The steel might be a lot more expensive though?
I used alumn mic/tooling plate when I made the "adapter" for my super spacer, before I remachined the slots to eliminate that plate. It did work fine.
I voted not to use aluminum because it the chuck gets removed from the RT often, alumn is easy to dent & bang up & may need stoning more frequently?
Almost same amount of work to make the backplate so make it out of a more durable material? I dunno, just a thought, I probably have no idea what I'm talking about.
