- Jun 12, 2014
- 5,101
When you look at how the forged steel chucks are made, they do not cast the voids in the back it is all machined. The Bison semi-steel have very clean castings and webing vs. the Chinese mainland ones I have seen. This is the TMX 8" 4J which is a copy of the Bision. Note that the through hole is 1.97" on the 8" independent chucks. The forged 10" Bison was gorgeous. I guess it depends on your needs, how much you use the chuck and how much you want to spend. Also these 4J independent chucks are more limited holding smaller stock, there are limitations to how far the jaws can come together and the jaws tips are wide. The 8" combination chuck can hold stock down to 0.2".
