Ray,
here is how I cast fire bricks, I use 26ga galv-cote sheet metal cause I have a lot of metal working equipment. No reason you could not use wood sealed and a wax for a mold release. If you were to make a 1-1/2 thick bricks with grooves for your heating element wire. Then pack around it with as much of the kaowool insulation, you should have a nice furnace. a trip to a pottery supply see if you can get the plates they use in kilns that will keep the parts at a nice height in the center of the furnace.
the problem missing and broken bricks
the form it unscrews from the back plate to help get the brick out.
mizzou mix is a APGreen/ Habirson product, not cheap but strong, I've used this in solder furnaces and wood burning stoves, they are much stronger than the older fire bricks.
following the instructions on the bag using minimum of water, give it a day or so to dry, take out make another one. Finding stuff cheap is getting harder to do, swap meets, auctions, good old Craigslist is the ticket.
You have a good size, I hate to fire up the big one it eats watts like crazy, and it's in the main shop, not the hot shop, not enough juice to run it there. The small one, well sometimes I can only do one part at a time, it takes all day. but there is plenty to do in there.
I'm interested in seeing how your controller works, mine are both semi-manual, it only cycles one section of heater wire you have to turn it to low/med/high or switch on the other elements 3 of the 4. it would be nice to have a timer maybe an alarm when it was done...or goes over heat. Take care! tt
