Heat treat 410?
)-1
This project was a oval hole punch for leather belt making. If I was going to purchase material specifically for this, what would be a good choice? Would A1 or A2 work well or would O1 or 02 be better?
0-! is easily found, relatively cheap, easy to machine and heat treat, that would be my choice. Look for it in McMaster Carr.
how'd you make the oval ? Lathe, mill? Eccentric turning? I'm curious. Can't help on the metals.
I have a 7degree end mill. I made an oval hole in a block of steel and hammered the round punch into the oval tapered hole in the block while it was hot.
One might use a commercially available gasket punch and modify it as you suggest.
I have a 7 degree end mill which I used to make an oval tapered hole in a block of steel. I inserted the round punch into the block while hot and struck it with a hammer.
I think s7 is a better choice and should be available.
Save the oil hardening stuff for blades, for a punch you want the toughness of air hardening steel. Else choose an alloy. You don't want hard and brittle for chisels, punches, or dies. You want tough.
For leather belt making especially, I’d submit there is little practical difference between O1, A2, and S7. But I suppose it depends how many belts you intend to make with the punch. At some point, you might favor abrasion resistance (e.g., D2). it may interest you to read some:
