author=Tenn link=topic=1723.msg25674#msg25674 date=1315953591
Saw several rather abrasive comments about not using brake rotors to tram a mill head. I can see your point but after very carefully turning a rotor down on both sides and checking it for flat and thickness tolerances to suit myself on a surface plate I find it quite satisfactory for tramming my mill head in. If you want or need tolerances closer than 0.001" then you will probably want something other than a brake rotor. My mill table is so badly scarred and abused by the former owner that those tolerances are quite satisfactory for my own purposes and probably for others as well. Just my two cents worth. I liked the idea of a large bearing race and I like the idea of the tramming tool as well but it's not in my budget so I make do with what I have. It is amazing the tolerances one can accomplish with less than perfect machinery if you have a bit of patience and do the best you can with what you have. ;0
