I have a question about material selection. The 3/4" thick A36 I'm using for the base has a springiness somewhere between Big Red and Double Bubble chewing gum. This is fine for the base, but now really appropriate for the spindle clamp, where you want it to open back up.
I don't have enough of the material on hand for both the trunnion arm and spindle clamp anyhow. So, I can buy a more appropriate alloy for the clamp.
But, will the A36 be appropriate for the trunnion crank. The design is for it to clamp on the trunnion and the worm gear shaft. My understanding is that clamping the trunnion is a one-and-done affair. But, do we expect to regularly clamp and release the worm gear shaft?
