You can often find craigslist-deals for a somewhat loved Kurt reasonably priced. A buddy of mine picked up 2 6" kurts for $60 (total!). They need some love, but were cheap!I just cant afford a kurt so i am like stuck inna rock and a hard place.
Can we get a definition around "pretty garbage"? Driving (and paying) for sub-tenths is kinda pointless on a round column mill.I'd be careful with one of those. I picked up the 4" one for a shaper-vise a while back and thought it was generally pretty garbage.
A major feature I was looking for was a deeper jaw death. To mill the bottom of these 6"x6" angles, the only thing I've been able to figure out is to grab one side with the vice, and let the bottom stick up. Without a good, deep bite, there was just too much flex.Did you check anything precision wise on it? That isnt a bad price for a 6" i may look at a 4". I have heard good things about https://www.amazon.com/dp/B07KP5LH5Y/ref=cm_sw_r_cp_awdb_imm_73EWZVJ3R07RM9ZXKVGP
Based on the work I did on the surface grinder, mine was out ~6-7 thou on the bed. The back of the jaw was out up/down about a thou. The 'clamping' jaw would lift by a surprising amount. Additionally, the 'bed' itself wasn't parallel to the bottom just about at all.Can we get a definition around "pretty garbage"? Driving (and paying) for sub-tenths is kinda pointless on a round column mill.
I did test the face of the jaw, and it was as flat as my indicator could tell, but nothing other than that. That's much better than the vice I was using, and is all I need right now. I'll verify the other surfaces before I use them.
I bought one of the 4" screwless, too. It doesn't have a pin to move. The ratcheting fixture on the bottom moves from one groove to the next.The 4" ones are a touch more expensive than the cast ones (https://www.amazon.com/HFS-PRECISION-GRINDING-SCREWLESS-TOOLMAKER/dp/B00NG15O1K), and use is a little tougher (to widen the jaws you need to move the pin in the side), AND are tougher to attach to the table (unless they have the hold-down slots, and even those can get in the way of moving the pin).
Ooh, nice! I've not seen a ratcheting one yet! I know a lot of the screwless vises end up having a version available with the hold-down slots in the side, otherwise making some sort of 'bar' to go through as the hold down is pretty popular. Can you share the link of the one you got? Maybe we can help him find something similar.I bought one of the 4" screwless, too. It doesn't have a pin to move. The ratcheting fixture on the bottom moves from one groove to the next.
Hold-down is an issue. Just like you said.
Ah, well, at least that one has the hold-down slots, so you can use a normal set of hold-downs. I'm sure someone can come up with some decent compact ones for that.I got the last 4". These are being sold on Amazon, Walmart, and eBay, and it looks like they are all the same seller, shipping out of the same warehouse in New Jersey, as the 6" vice that I also bought.
VEVOR Screwless Vise, 5" Precision Vise, Sine Vise Parallel Accuracy of .0002", Precision Grinding Vise 2" of Jaw Depth, Mini Vise, Machinist Vise, Mini Toolmakers Vise for Grinder Milling Machine - Walmart.com
Free 2-day shipping. Buy VEVOR Screwless Vise, 5" Precision Vise, Sine Vise Parallel Accuracy of .0002", Precision Grinding Vise 2" of Jaw Depth, Mini Vise, Machinist Vise, Mini Toolmakers Vise for Grinder Milling Machine at Walmart.comwww.walmart.com
[Edit]. I haven't used or measured this vice yet. Just checked it out visually and sat it on the shelf so I could get back to making dividing head parts.
The only way to tell was to buy one. You loosen the big bolt enough, the fitting drops out of the slot, then you can move it to another slot.I guess I don't know how to tell it is 'ratcheting' then.
