- Jul 30, 2017
- 635
While restoring this lathe, Questions concerning Oilite bearings and electrolysis came into question..
I did some research on Oilite bearings, there is lots of info on the subject along with some bad & misinformed info on the net.
The most important Question about oilite bearings is, can they be re-impregnated with oil.. Answer is Yes.
Another important Question about an oilite bearing is, can they be machined.. Answer is Yes.
should you grind sand or polish an Oilite bearing, Answer is No. These actions will close/clog the pores.
This site has some techincal info on the subject. Machining Oilite Bearings.
And this one you'll have to read threw for the recommended procedures of oil re-impregnation, not a direct link but can be found on this Bowman Oilite Page.
There are two recommended ways to rejuvenate an Oilite bearing, Note: some application require a specific Oil Type such as in contact with food.
1. Fully submerged and heat an Oilite bearing in oil to 80 deg Celsius or about 175 deg Fahrenheit, let the oil submerged bearing cool off completely. remove, wipe excess oil from bearing and its ready for use.
2. Use of a vacuum pump. Fully submerged an Oilite bearing in a light weight oil in a container, apply a vacuum to the container to pull air & moisture from the voids in the bearing for a few minutes, release the vacuum and oil will be pulled back into the voids.
While there are other recipes found on the web.. Those links are from competent sources so ill just head down that route. Till next time.. Mike.
Ps.. SAE 20wt Oil for re-lubing - I could not find an answer if this was a none detergent oil, I would think a none detergent oil because oils with detergents are used in high temp applications like engines.
