- Jul 30, 2017
- 635
What a superb job you are doing Mr Mike. It's going to turn out so nice that you may not want to use it...LOL
Hello HRgx, Thanks so much for the kind words.
Provided you paint is not a two pack type, you can drain the thinned primer back into an empty can, then wash the gun out, and put the thinners into the same can, and use that for thinning more primer or topcoat if you are washing topcoat out. Also disconnect the pressure and squeeze the trigger to allow the paint in the mixing chamber to drain back into the cup. Both paint and thinner are expensive, waste as little as possible, and use a cheap gunwash thinner to clean the equipment after all the best thinner and paint are removed. She's looking good!
I saw a fully restored Monarch 10EE on Pinterest. It's the red one. The fellow laid some pin stripping on it. I do think he went a little overboard with the pin strips. However, if you did some tasteful and not too busy pin stripping, I think that it would look real nice. Just my opinion but whatever you decide, it's gonna be a show piece.
This is a net project you have undertaken! Lots of diversions along the way - electrolysis, painting, restoration, and in the end a machine you will know in and out!
