Sounds very much like something I would do. Teach people to think about what they are saying. What's that old saw....."Make sure your brain is in gear before letting out the clutch on your mouth" or something like that.
<Dusts off his ragged, abused bio-chem major hat> Pretty much anything which oxidizes readily can catch fire or explode in dust form. Note that this includes many forms of iron and aluminum. It has to do with mass-to-surface-area ratio. Oxidization is a heat-generating reaction (exothermic, to use the $5 term). If you have a big mass to absorb that heat and little surface area at which the reaction can happen, you don't get much except for the formation of an oxide film (i.e., rust or patina). When there's no place for that heat to go internally, all it can do is go out into the environment. In a pile this can quickly become a fire. Floating around airborne, this can go "boom!" Just yet another reason to keep your workspace clean!
[edited for clarity, 12/6/2016, 6:13 pm CST]
It's actually aluminum and iron oxide dust. The red iron oxide (Fe2O3) or rust, that is. I'm not sure that the black oxide (FeO2) or scale from hot worked steel reacts the same.Aluminium and Iron dust mixed together happens to make a thing called Thermite. Little spark and that mix will burn through anything. Very dangerous stuff.
