I had a nerve on the outside of the cut that finally callused over but for probably 5 years it was just like getting shocked with 110 every time i touched it
Why would one use a volatile, flammable liquid as a coolant for a tool that has an open ignition point (that is, the spark)?
The kerosene works extremely well as long as the ignition point is kept submerged.
Lots of things are flammable in a dust or powder form----try a little coffee creamer powder--burns well
Even many things that are not flammable can be explosive when in dust form.
I've never seen it for myself but I remember a story about a table saw being used for cutting steel & apparently pine dust is much like gasoline.
Liquid kerosene will not burn. Like gasoline, and diesel, it needs to be mixed with oxygen to support combustion. Gasoline appears to burn, because it vaporizes easily, and that is what you see burn when you toss a match in a bucket of gas. Unless it is a super hot day, you can toss a lit match in diesel or kerosene, and chances are the match will burn a few seconds, then go out. You need the vaporization of the fuel to get the flames. That's what Savarin caused by slowly adding kerosene to hot metal with sparks.
And a lot of automotive fuel pumps are submersed in the fuel tank and the fuel flows right over the commutator and brushes.
exactly why I decided on distilled water for my EDM.......I can't be trusted!
(@savarin, it is not meant as a gloat or "I told you so", just as a example of a compromise/substitute for safety's sake).
Yes my EDM vise is rusty, I want to try a wax coating or something......
Interesting. So the EDM doesn't push enough wattage to crack the water into free hydrogen and oxygen? That would create a whole new set of flammability issues!
So as a question to all and sundry who actually have EDMs. What about standard cutting fluids like emulsified synthetics makes them less desirable here? Conductivity issues? Cost?
