Mt
how about clearing swarf on the lathe. Never ever use ones hands to push, clear, untangle the swarf building up. Use a brush to push it away or perhaps smooth handled pliers to try and grab some. The idea is that you don't want the pliers to get caught and pull your hand into the works.
Best of all turn off machine and remove the swarf and build up.
Swarf ...the bane of a machinists life .
Never ever use an airline to blow it away or clean the lathe for your likely to get blinded or impaled by the tiny high speed razor sharp bits of turned off metals your blowing around .
Always use the power off kill switch to ensure the machine cannot be accidentally turned on during cleaning operations .. never ever clean a turning machine or remove swarf from one , its far too dangerous.
TIP.
My pal has put a rather strong toroidal/ doughnut magnet ( taken out of an old scrapped microwave oven ) into a home made can using 3 inch dia thin wall aluminium tube & an end plate " Tigged " on all the way round the joint .
The magnet is glued to a pull lever which has an end disc / flange of aluminium screwed onto the end so it looks a bit like one of the caulking guns you use to put sealant on out of a plastic tube .
The rod runs up the inside center of the can .
Between the magnet & the top of the can is soft 6 inch long compression spring over the pull rod . At the very top of the can is a light steel cross brace with a central hole in it .
The pull rod pokes up out this hole & the top end has been shaped to form a finger grip for four fingers .
Riveted to the top outside of the can above the furthest reach of the pull rod is a simple inverted " U " shape flat bar handle 3 mm thick x 13 mm wide .
Run a two inch wide strip of quality industrial grade sticky plastic tape round the can about 3 inches up from the base of the can , if it's placed thoughtfully it will indicate the average area of attraction to the ferrous material when it's at rest down a the bottom end of the tube .
To quickly & safely collect the smaller ferrous swarf you put the magnet end of the aluminium can over the swarf area & it picks it up . If you have birds nests of turnings then why not make yourself a swarf hook / scraper off device ? Make it out of some 3 mm thick x 13 mm wide by 22 inches long flat steel /stainless steel bar & make a formed ring at the opposite end to the 3" "L " shaped hook to hand it up by .
Move it over to the waste bucket , one handedly pull the lever with the magnet on it up & the swarf falls off the aluminium case & lower side of the can . Release your grip & the spring pushes the magnet back to theh bottom of the aluminium can ready for the next go .
Store this magnetic swarf picker up / collector anywhere that has a steel surface to stick it to , for it is magnetic after all .
