CNC lathe, it will run all day without input, sometimes the chips between material production runs will cause problems however. It is best to run several parts whilst adjusting the feeds and DOC's in order to get the chips under control, once this is done let it eat, the next bar may be different.Ok, you went to get a cup of coffee. Glad I do not drink the stuff.
been there, done that, it hurts before you realise whats happening.Those sparks can set clothes to smoldering. Tennis shoes, pant leg, etc. Watch where the sparks are hitting, They may not seem that bad but as you grind they continue to build in spots.
I've never seen it for myself but I remember a story about a table saw being used for cutting steel & apparently pine dust is much like gasoline.Those sparks can set clothes to smoldering. Tennis shoes, pant leg, etc. Watch where the sparks are hitting, They may not seem that bad but as you grind they continue to build in spots.
And like Tony said if you share your work area with others, or even other things like wood working, be careful. The saw dust can be a ready fire starter, Have seen those results in one garage shop,
keep the fire extinguisher handy.
