Bill, thanks for all the info! You're not long-winded. Look at one of my posts... Now that babble-fest is long-winded. Judging by the amperage on the data plate for this motor, I'd guess it's around 15 HP. When I go looking at specs on 3 phase motors, one with a rating of 38-40amps at 240v is usually a 15 horse.
Does this lathe even do instant reverse? I don't know, newbie that I am. If so, will it work with a rotary phase converter? I read somewhere you couldn't do that with a static phase converter, but don't know about rotary.
I'll be getting a rotary converter soon. I figure I'll need one that will start a 15hp at most.
Anyway, I'd like to start figuring out that stuff a little. It will be a bit before it runs. Who knows what I'll end up needing? I expect probably a transformer for the controls, relays, blah blah blah. Basically, all new electrics, maybe including motor.
Thanks!
Mark
