- Sep 13, 2016
- 137
VFD basically is a variable speed electrical control with programmable accel/decel profiles, and reversing. IMO, with that machine you don't need the reverse. That motor will run (in its original configuration) in one direction, with reversing of the spindle coming from the gearbox. As far as the accel/decel that's a nicety, but hardly a necessity. A VFD can be set up with a brake, but their main claim to fame in the hobby world is the ability to run 3 phase equipment on single phase. HOWEVER, the size VFD for a 15 hp motor will be pretty healthy, and priced to match. You said you did not have native 3 phase, correct? Another issue you will need to address is the current draw for a motor that size. Even with 230/240 available, how much current? You're probably looking at ~40 amps continuous on that motor. It's on the plate if the plate is still there. That's another major factor in sizing a VFD. We have some here who are very well versed on VGD applications.
I personally am not a huge proponent of VFD's, but some people are. I have been around them and used them on a few things, up to 250 hp, so I do have some experience with them. On machine tools, I must have some bit of purist in my heart.....I like to see them as designed, for the most part.
Tony,
My plan had been to buy a rotary phase converter large enough to handle this lathe, knowing anything else I'll have that's 3 phase will have a lower power requirement. The RPC I've been looking at should give me what I need, but requires a sixty amp breaker in my panel. I'll have to buy one. Plenty of room for it, both in terms of physical space and total amperage. You're right on the amperage, or close enough. The motor currently on the lathe is right at 39 amps, and the replacements I've looked at are all within 1amp of that either way. It's just what it takes to run a 15HP motor, so no surprises there. Looking around as I've had a spare moment or two, I notice there are other limitations on a VFD. I'm really thinking my best option will be the RPC sized for my needs. Wire up a circuit for it, let me power whichever machine I need at the time, and go on with it. Of course, I'm always open to other arguments.
Thanks again!
Mark
