Fly Cutter recommendation
mwebster51
Jan 1, 2020
134
I have a Precision Matthews PM-25MV, so a smaller mill. I am considering purchasing a fly cutter to be used mainly for mild steel, typically less than 3" wide. I am just skimming the surfaces and only want to remove 1-3 thou of material at a time . It is my understanding that fly cutters that use carbide inserts do not work well when taking cuts less than 5 thou. Can anyone recommend a fly cutter that will work well when when removing 0.001" to 0.003". Are there any fly cutters with inserts that will work well in that range? Thanks
I've seen some far east import insert cutters that look okay recently, but never run one. @Eddyde nailed it, though. I just wanted to post to plug the best flycutters I've ever used, the Lopre/Flexbar dual rougher/finisher design. I have a 7" that I use for cylinder heads where I want skim control and high finish. The design allows for some pleasing options, like using a larger tip radius finisher along with a cobalt rougher. I just picked up a 3" for general purpose for when I need thinner passes than my old faithful insert face mill can do adequately.
Make one. I built one that covers 3" and used the 5/16" Silver soldered lathe tool as the cutter.
I was going to call out @MrWhoopee - he once ref'd some flycutters from AliExpress(?) that he said worked great.
There really isn't that much to a flycutter ( or there needn't be ). Another one to make:
An insert cutter can cut very finely, though you may need to use inserts designed for aluminum or otherwise ground inserts to work with that very light cut. A traditional flycutter (like @verbotenwhisky showed) is a contender, and where most of us start, just watch the balance and mind your cutting geometries.
GsT
DavidR8 recommended a Tormach Superfly Fly Cutter on the Canadian forum. I've had that same fly cutter for a number of years and have been very satisfied with it.
Regards
