- Apr 29, 2019
- 2,281
I have a stainless steel panel that .063 thick made out of 304 ss.
The panel is all finished with hours of stamping and has been formed and welded into position.
I just noticed a typo. there is one character that needs to be removed and the new character stamped.
There is solid material behind the plat so the stamping will not be an issue.
I am looking for good ideas on how to "erase" the wrong character.
The surface is just the mill finish, nothing special.
My thoughts so far; (in no particular order)
All methods of erasing will get a light sanding over the entire plate to even out the surface finish and then restamp the correct character.
1. Touch it with a TIG welder.
2. A light peening with a small ball peen hammer.
3. Grind off the wrong character with a Dremel or similar.
Any other ideas????
Any other ideas????
