Try running the head at higher RPM for aluminum, 2500-3000 RPM, you can play with the speeds but probably 10-12 IPM. It also depends on the depth of cut, for higher removal rate,deeper/shouldering cuts I decrease the RPM. As others mentioned some air/light lubrication helps clear the chips and prevent chip welding.
