- Apr 10, 2021
- 621
If rent a drop deck you can use it for both machines. Two trips likely. The lathe is the tougher load but you can roll it on with pipes or load with long forks. I'd put a pallet jack in the front and drop the lathe so the light end is on 4x4 blocks with the jack between and the two strapped together. A second jack on the headstock end with blocks. you and a strong friend can push and pull the lathe off the drop deck.
One person can handle the mill but two are better. I use an electric jack. Because the drop deck will have a steel bottom and flexes some, I'd put 4x4 bolted to the mill base ( not lagged ) and longer so the machines seems less tippy. Lots of straps. there is nothing worse than not being sure about the load and spending the whole trip watching the rear view while idiots pull out in front of you assuming your brakes can handle the inertia. Dave
