I would look at the Sharp with DRO, 42" table. Located in Punta Gorda. Looks to be in the best shape, comes with a modern DRO and a Servo X drive, price is reasonable. Should be the LMV-42 (or Acra LCM-42) and they typically come with R8 spindle although there are other options. Would ask if everything works, and if anything is broken. Reeves drives can wear and become noisy over time, often an issue with older mills and repair can be a bit of a pain and costly. I also would check to see if they are 3 phase. Frequent stop/starts with a single phase motors, the start capacitors usually goes. You can add a VFD for not much, if using a Reeves drive, you just use the VFD more as a fixed 3 phase source for the motor and change the speed with the Reeves drive. A VFD is much cheaper and quieter than an RPC. I have the same mill, although a newer factory VFD version, they are very nice. Current version of that mill will be around 9K similar equipped.
