- Dec 20, 2012
- 9,422
Since we're on the subject... What are some good hobbyist-quality brands to look for? I'm thinking of getting an ER32 collet nut and some collets for my lathe. I would make the holder myself.
If you're going to use the collets on a lathe then I suggest you buy a complete Chinese set on ebay. You do not need to go with quality collets for work holding on the lathe; import collets will be close enough for most work. Using a good nut will help accuracy, even with these cheap collets.
If you are using the collets on the mill for tool holding then buy the best you can afford. The cheapest "good" collets I know of are the Techniks brand; runout in the low tenths and possibly better if the chuck and the nut are good. In order of cost, Lyndex, Crawford, ETM and Rego-Fix are other good brands.
Buy a decent nut because it makes a difference. Rego-Fix Hi-Q nuts are very, very good. ETM nuts are just as good. I have not tried them but Techniks is said to make a good hardened nut. Rego-Fix also makes a ball bearing nut that I haven't tried ... yet.
I use a 3 jaw chuck to do first operation turning on the lathe. I only use the ER collets to hold turned or threaded parts for second operations. This gives you accuracy when you need it and you aren't cranking down on stock that is uneven. For the occasions where I have a lot of nominal stock to turn, I use 5C collets that are intended for such work.
