Finally got some shop time in. I have the motor connected and forgot to get a pic. I grabbed the latest code and played with the settings. I have 2 problems right now.
1) There is a slight gear ratio in the built in gearbox that I am not adjusting for. When I get it close by just tweaking and testing, I'm darn close on threading. I think if I can figure out the ratio in there, I can get it dialed in.
2) This lathe has a separate drive line for feed that doesn't use the lead screw. This does not appear to match the lead screw, no reason it should. So I'll need to update the code to support that. I'll contribute it back to the project once I get it working.
I did do some test cuts when I managed to get feeds close. I think it will work well once I sort out some of the issues.
