The photos I took are in the thread above. If you click them you should be able to get a larger version.
The encoder mount is simpler than it looks. It's a piece of aluminum block squared off, then drilled to match a right angle bracket I milled some slots in. It's held down to the arm with a pair of T-nuts in the arm slot the same way the stock gears are. The bracket also has holes drilled to mount the encoder on the other side. It's just a piece of angle aluminum.
The servo is on a pair of brackets. The first is a commercial unit that fits the motor. I got lazy and it was something like $5/pair. The other is just more angle aluminum with slots. It's mounted to the lathe with some holes I drilled and tapped.
The exact mount locations are determined mostly by the belt length. So I just found a spot that was about right, added a little space for adjustment, and put the holes there, leaving some space in the slots for adjustment.
