The two questions I still have are: 1. What is the maximum torque that the lead screw will encounter during turning or threading and 2. what does the torque speed curve look like for any given choice of motor.
The first is dependent upon the depth of cut, the feed rate, the material being cut, and the geometry of the cutting tool. The relationship between the input torque on the lead screw and the delivered force, neglecting friction, is torque x rotational angle = force x distance. My lead screw has 12 tpi and therefore moves .08333/ revolution and ine revolution is equal to 2π radians so the force delivered = torque x 2π/.0833 =75.4 x torque (torque in lb.-in. and force in lb.). If my input to lead screw is 200 oz.-in, or 12.5 lb.-in., I could deliver 940 lbs. of force to the carriage drive, less frictional losses. My carriage crank has a mechanical advantage of 11:1 so I would have exert around 85 lbs of force at the crank to create the same 940 lbs.
The second question is more difficult to answer. When I dealt with NEMA 11 and NEMA 17 steppers in the past, I had published torque speed curves to guide my selection. Unfortunately, the motors that I have seen for this application don't seem to have that information available. Additionally, looking at a variety of motors on line, there doesn't seem to be a set relationship between holding torque and and available torque at speed. I am considering two motors at the present; a stepper with 425 oz.-in. of torque and a hybrid stepper with 602 oz.-in of torque. My gut is telling me to go with the more expensive hybrid but I really would like to see some torque curves for it. The hybrid can run at higher rpm so torque multiplication via gears is an option. Unfortunately, conventional steppers don't enjoy the same advantage due to the serious decline of available torque at increases rpm.
As to actually measuring torque, it should really be done at the desired operating speed. A dynamometer would be useful. A simple one could be constructed using a brush type motor. A cordless drill/driver comes to mind. The speed control would for the drill would have to be disconnected and the two power leads connected to a variable resistance. The voltage across the resistance and the current through the resistance would be monitored as the resistance was slowly decreased until the stepper lost steps or the hybrid errored out. The product of the voltage times current would be the output power in watts which could be converted to horsepower at 748 watts/hp. Horsepower - torque x rpm/5252 so, knowing the rpm, you can calculate the delivered torque. Torque in lb.-ft. can be converted to oz.-in. by multiplying by 12 x 16.
