Reply to Guns:
When you say "someone here just bent the 5 connectors" that was me. Rather than burn out another LED&KEY board in the control panel by trying to de-solder the 5 pin connector, I bent the pins over by about 60 degrees and pushed in the connectors I was using. However the length exposed was insufficient to hold the connectors securely so I pulled the end insulators off, soldered the ends to the 5 pin on the LED&KEY board then applied heat shrink tubing. Overall it is a bit thicker than Clough42's approach but it was easier for me. It still meant that there were 5 solder points to be done.
Regarding the daughter board/booster board, I suggest you look at it again. There are two 20 pin connector blocks (requiring 40 solder points), 4 solder points for the 5v supply, 6 for the stepper control connector, and 5 for feed to the control panel.
Including the control panel that adds up to 60 individual solder joints.
