- Feb 1, 2015
- 9,983
I think I roughly follow you, and I should be able to muddle through. The flashing and parameter setting parts of this project will be the big challenge for me.
Here's a combo I was looking at:
Thoughts, anyone?
Yesterday I ordered Clough's interface board, a 1024p/rev encoder, Launchpad, 5v supply, display/control panel, Bud box. Here goes!
The last things to figure out are servo, driver, power supply, drivetrains for servo and encoder, nuts-n-bolts stuff.
One more point I'm a little lost on - will I need to source the connectors to hook stuff up to the interface board? From the pictures, it doesn't look like the male parts of the connectors are included…
Your stepper choice sounds OK. You can correct somewhat for a undersized motor by changing the ratio if the stepper pulleys. Clough uses a 3:1 ratio with his motor. Stepper motors lose torque with increasing speed after a certain point determined buy the motor
Here is the torque curve for your motor. https://www.omc-stepperonline.com/download/34HE46-6004D-E1000_Torque_Curve.pdf
As you can see, if you were operating with a 1:1 pulley set and at a lead screw speed of 300 rpm, you would have 420 N-cm of torque. Changing to a 2:1 pulley arrangement , the stepper speed would have to be 600 rpm for the same lead screw speed and the stepper torque will be about 250 N-cm and the torque at the lead screw will be 500 N-cm for a 19% increase. Going to 3:1, the stepper would run at 900 rpm@ 170 N-cm and x3 that would be 510N-cm or a 21% torque increase.
On the other end, most threading will most likely be done at low spindle speed and threads finer than 8 tpi. so you will be operating at around the 150 rpm range. Torque demands aren't all that great when threading as well.
You should have no trouble with the programming and flashing. It went without incident for me. The connectors for the interface board are included in Clough's kit. He has a video on the assembly process. (part 8, I believe)
