Cheers, Greenail,the maintainer of grblHAL made that MPG which is called GRBL_MPG_DRO_BoosterPack. The firmware and pcb stuff is on his github repo so you can make one!
Thanks for all ur efforts here GreenailSo, grbl was highly optimized for 8bit arduinos and has been very very successful for folks running real production machines. Lately there has been quite a lot of development for faster processors with more memory which is exciting. Bart Dring released open source hardware and a grbl port to the esp32 that I have been using for over a year. You can buy one of his boards on tindie.com or you can make your own (i've done both). Bart's port supports trinamic drivers, laser mode, hobby servos with step/dir and a whole bunch more. It is stable and because it uses the esp32 it can support much higher step rates so you can get smaller microstepping if you need it! The 8 bit arduinos really struggled with >16 microstepping. The great thing about he esp32 is that is is very inexpensive and easy to get.
grblHAL is another port of the classic grbl codebase which also supports esp32 but it supports a bunch of other boards and it is designed to make it easy for follks to add new processor architectures. Generally the jogging on grbl has been sub par due to trying to squeeze it onto an old arduino with very limited memory. The newer 32bit processors generally have much more memory available so more can be done to improve jogging (as you can see above by his MPG). grblHAL also has some preliminary support for spindle sync and G76! Finally terjeio is working on his own gcode sender that enables support for his grblHAL specific enhancements. This seems the best fit to use to make a ELS since it already handles the spindle sync, step generation, acceleration motion control etc. Again, it would also do full CNC if you needed it to.
generic grbl:
Home
An open source, embedded, high performance g-code-parser and CNC milling controller written in optimized C that will run on a straight Arduino - gnea/grblgithub.com
a decent video:
bart's port:
GitHub - bdring/Grbl_Esp32: A port of Grbl CNC Firmware for ESP32
A port of Grbl CNC Firmware for ESP32. Contribute to bdring/Grbl_Esp32 development by creating an account on GitHub.github.com
bart's blog (generally interesting)
In theory, a stepper has an infinite torque at zero rpm. In practice, it is limited by the resistance and inductance of the stepper.The theoretical torque is inversely proportional to rpm, torque x rpm = constant. The constant is dependent upon the geometry of the stepper and its electrical characteristics and will vary within motors of the same frame size and detent torque. We used to use NEMA 17 motors from Oriental Motors and they have published torque/rpm curves for their motors. The curves vary quite a bit between similar motors.
I made a decision on a motor for the 602 based in part on James' success with his hybrid stepper and that my Tormach steppers are 500 oz.-in. I ordered a 600 oz.-in. hybrid stepper and driver kit, https://www.ebay.com/itm/233342928169 . I plan on using 1:1 pulleys to drive the lead screw. I'm hoping that the inproved high speed response of the hybrid stepper will be sufficient. My gut is telling me that the spindle motor will stall first. If necessary, I can use the 2:1 gearing in the gear box to boost the torque.
My next concern is the power supply. The stepper has three phase windings and a rated current of 5.8 amps/winding. Does this mean that I need a power supply with a 20 amp rating? At 48 volts, that's 1,000 watts. That seems a more than a bit large. The Tormach has a 400 watt linear supply and is driving two 500 oz.-in steppers and one 700 oz.-on. stepper.
RJ, I see that the motor you chose runs at 200 steps/rev, while the one James used is 1000 steps/rev. Did this require a change to the code? I have zero experience coding and I don’t want to get into a project too deep for me to wade through!
James is using a servo with a built in 1000 step encoder. Yes, you will have to change some parameters in his code. He explains how to this in part 10 of his video series.RJ, I see that the motor you chose runs at 200 steps/rev, while the one James used is 1000 steps/rev. Did this require a change to the code? I have zero experience coding and I don’t want to get into a project too deep for me to wade through!
You can change various different parameters to achieve the desired output ratio depending on your particular situation. I use a 2:1 gear reduction in my gear box to increase torque to the lead screw and changed a parameter accordingly. For instance, I could change my srepper resolution to 400 steps/rev. or change the lead screw pitch from 16 to 32 with the same effect.RJ, I see that the motor you chose runs at 200 steps/rev, while the one James used is 1000 steps/rev. Did this require a change to the code? I have zero experience coding and I don’t want to get into a project too deep for me to wade through!
