What sort of current is needed? In round numbers, a rectifier (without a capacitor filter) that outputs 400 VDC peak voltage needs about 285V VAC RMS for its input. A rectifier that outputs 400 VDC AVERAGE voltage requires 450 VAC RMS for its input. Which do you require? How much current is needed?
In either case, the voltage can be had a number of ways:
Isolation transformer, step-up, followed by a 4 diode bridge rectifier.
Isolation transformer, center-tapped, step-up, followed by a 2 diode bridge rectifier.
Auto-transformer, boost type, followed by a bridge rectifier.
Switch-mode power supply, chosen for the DC voltage required.
For small currents, there are circuits called voltage multipliers that consist of diodes and capacitors. Typically for a handful of milli-amps.
All of these come with safety-related issues that have to be considered.
