I submit that the size and rpm of your motor should be calculated from the actual requirements of your grinder. For roughing with a coarse belt, many belt makers recommend 6000 feet/minute belt speed. To run very high grit belts at 6000 sfm would shred them quickly. For e.g. a 1200 grit belt, you want something like 600 sfm. So a good design goal is 600-6000 sfm.
The belt sfm is proportional to the drive wheel diameter. SFM = PI * DIAM * RPM / 12
as long as your drive wheel diameter is in inches.
If you have a 6" drive wheel then your belt speed will be 1.57 * RPM. If you plug in 1750 for rpm you get about 2750 sfm. If you overspeed your motor to 120 Hz (about the limit of what you can do safely) you get to 5500 sfm. That's why you might consider a 3450 rpm motor.
As for size, you want as much hp as you can afford. Be aware that a 3hp VFD is quite a bit spendier than a 2hp VFD. And of course the bigger motor costs more. Also, your grinder is probably designed with a range of motor frame sizes in mind. If you buy too big a motor you may have to modify your grinder so the motor will fit.
Finally, if your grinder has the modern feature of being able to swivel the platen 90 degrees, a big motor may make that into a seriously muscular event.
I recommend a 2hp 3450 rpm 143 frame motor for a 2x72" belt grinder. I built one in 2011 which had a 3hp motor and I doubt I ever needed it.
BTW when you are really roughing be sure you have a spark catcher of some kind else you may literally catch your shoes on fire.
metalmagpie
