As noted in my post below about my new LMS 7500, I need to make some kind of chip screen to catch the swarf coming off the front, a problem I really never had with the Logan 820 since I wasn't running at these spindle speeds.
I'm trying to research a thin transparent plastic sheet that I can shape to hold in a DI stand, with an arc partly over the front of the chuck and curving down to the chip pan. I do know that ABS is heat-molded, but that's the extent of what I know.
What sources/brands of ABS have you used successfully? How did you mold it?
Many thanks for the help.
Tim
Tim
