- Oct 31, 2014
- 444
I am surprised nobody has mentioned the Vise Grip drill press clamp device.
I have one on the table all the time, only removing it (one wingnut) when I need the full flat table area. Routine is to position the work under the spinning drill bit, find the center punched location by 'feel', then position the clamp and adjust to hold the work down and avoid slicing my hand if the workpiece gets jammed. Easy peasy. These clamps are about $15 on eBay - Search for 'drill press vise grip clamp'
Came with a pad to avoid marring the workpiece, or use without on stuff that isn't critical.
Using an auxiliary vise (such as for round stock) you can clamp the vise to the table with the Vise Grip device.
Worth its weight in platinum IMO.
Stu
Stu
