The 1/64" collet looks OK but the collet to the right of it appears to be mismarked. It looks a lot closer to a 1/8". The one on the left doesn't look right either but it may just be the lighting.
"Completionist". I love the new word. I struggle to be successful at it.
It's a special, subtle sort of full options, "have the whole set" kind of OCD!
I also think that it is an emergency collet that they marked 1/64”. I don’t know if you can tell from the photo, but the area around the center has a different surface finish which may be interpreted as a non-hardened area that one can drill into.
The Shars collets were $6.93 each + shipping. I will stop before I post something bad about Chinese products, although I will note that the 1/64” collet is marked Shars, and the 1/32” one has no marking. All 118 of the Crawford collets have consistent markings.
The emergency collets that I have seen have three holes for pins on the slots so the collet can be securely tightened for machining without closing the slots.
