- Mar 21, 2018
- 1,727
It doesn't look like the compound has seen many crashes. I would surmise that the device that needed the grub screws tightened down so hard as to deface the top surface is the culprit (well, the grub screws anyway).
If you have a mill, grab some steel stock (or cast iron, if you can afford it) and make yourself a new compound. Except for the dovetails, it doesn't look all that complicated.
