If the seller can measure the diameter of a pin (camlock stud), it will confirm which spindle taper it fits. D1-5 has 3/4" diameter pins, D1-6 has 7/8" diameter pins.
Yes, my bad. Thought it looked like my D1-6 but the picture might just make the pins look larger - or I needed coffee. As Mark said, have the seller measure the diameter of the pins. Dave
