D1-4 chuck questions
oogenshire
Jul 22, 2022
144
i have a jet 1440 lathe and the other day decided to clean and lubricate my 3 jaw chuck that was mounted on it. took it off de greased it (probably original factory grease in it nasty stuff) put it back together and went to put it back on the spindle. i ended up turning out the pins like 3 turns before i could get the cam lock to engage properly? when i re assembled the chuck i screwed the pins in all the way, is this normal?
My 3 jaw D1-5 came from the factory with one of the pins in the wrong place. I had to turn it out a turn to get it to lock.
