Thanks for sharing! Could you please confirm if the air cylinder is an Airtac ACQ100X15? (I can partially read that from the sticker in your picture.) Also, what thickness of aluminum did you use for the base plate?I spent more than I should have on my initial 440 CNC package a few months ago, and I'm very glad I bought it rather than a manual mill, but I need to get it paid off before I can justify spending more money on more accessories, but seeing Tormach release the power drawbar for the 440 made me want it even more. $700 for the factory kit isn't bad but I thought if I could get a few components cheaper I could make one that suited my needs just fine it didn't look that difficult and I saw a few others had made their own versions so I had a little bit of a template to follow. I ended up about $240 in everything I needed even had twice as much 6061 just in case i needed a do over, but I was surprised the first version worked very well. I didn't take pictures of each stage which it really wasn't a lot, the base plate, 3 standoffs threaded at each end, hardware and air cylinder. I got a 100mm x 15mm cylinder from ebay for less than $50 and a cheap foot pedal for $27, the hose and fittings was about another 50. I probably had less than 2 hrs machining everything. I have my air set at 90PSI and it operates well at that air pressure. If your even thinking about adding a PDB just do it, it is very simple, inexpensive and makes running the Tormach so much nicer.
View attachment 234541 View attachment 234540
Thanks in advance for your help!
