Thanks Rich.
I plan to use perforated metal for a grill but it is stupid expensive. Anyone got a good source for a small amount. Would it be stupid to try to make my own with a drill?
Robert
I if you have some type of xy table you should do fine. Else, just measure very carefully
At lowes, in the section of the store where they have angle iron, steel, threaded rod and such, they have aluminium sheets, sheetmetal and perforated panels of different types. You might find something there that suits you.
I will check Lowes! If not, I have a small piece of perforated aluminum that I can use as a drill guide. That should make it go a lot faster. I figure its about 100 holes. At 10 sec per hole that is 16 minutes. Lets say 30 min to be conservative.
Robert
