Hi K , working on it right now ? Waiting to hear how it goes . Mark .
Just got up from the basement. It's been an interesting night.
The spindle looks great, I would say it came out of a lathe that was never really used. I'm pretty happy even if it was a bit more then I wanted to spend.
I first tried to install it with my new bushings. I could get the spindle in but the amount of friction WAY to high. I could hardly turn it by hand. The new spindle came with it's original bushing so I carefully replaced them and pretty much ran into the same problem. I was not in the best mood.
So I pulled the bushing out and really looked at them closely. Turns out you can see the "pinch point" in them so after a little more investigating I was able to also figure out the orientation they were in. I put everything back in the way it would have come out of it's original home and I was able to turn the spindle by hand with a chuck on it.
Everything was well lubed up so I figured what the heck lets see if they will run in. It spun up, I let it run for 30 second or so then flipped the switch off. There was still enough friction to act as a brake which spun my chuck off! The darn thing put two dings in my ways, I may have let a few bad words slip. Luckily the dents are dead center where neither the carriage or the tail stock will interfere. Dodged a bullet but still not happy.
So I started running it in again (with out a chuck) and it loosened up. After a while I put the chuck back on and to a few passes on the 12L14 steel and got some much improved results (sorry for the blurry photo, my phone wouldn't focus).
The spindle spins well now with just a touch of pressure from the screws. The housing feels warm to the touch after running for a while but not hot enough that I can't keep my finger on it.
The reading from my dial indicator shows (on the same piece of steel from my photos above) a pretty big improvement vertically, just a few thousands down from .010" Horizontal play didn't improve all that much, .004" down from .005". Maybe that's just normal, I mean you have to have some play in there. I also noticed that it does vary if the machine is warm vs. cold.
So overall I'm happy. I'm mad the chuck came off but it's not then end of the world.
Now a question. I'm using some tap cutting oil I had around. It seem to turn into instant smoke when cutting. Is that normal? Remember I don't have a clue what I'm doing here, I don't seem to see the guys on YouTube have these problems though.
K
