Lucas I understand your desire for very accurate gauge blocs set, and if you can afford the best, then why not? However as your OP implies being on a budget makes one open to cheaper alternatives... I bought an offshore uncertified set about 35 years ago. I have measured it in a lab against their best set using a half tenths indicator that could be read to about a third of that. Only one block had any discernible deviation.
What I'm saying is that you get a lot for your money no matter what set you buy.
Now tracking requirement for precision: are you machining to one thou precision, half thou or better? My own personal opinion machining for 40+ years, and having firends in the trade much longer is this:
Develop skills and techniques like lapping, turning, finsihing and honing. Use the best measuring tools you can afford. With 25+ years experience, you will be able to reliably machine and finish to sub-thou. Many home machinists fool themselves into thinking they can do better.
Even on the best surface grinders, for instance, it takes years to become a grinder hand and grind to 2 tenths overall and square. The best a beginner can hope for is around 5 tenths on a new, tight machine, properly dressed wheel proper hardness and grit with perfect cooling.
The Shars sale one will do you for many years. If you develop the skills to even measure to better tolerances, you will have hundreds of thousands of dollars invested, and buying a better set will be a drop in the bucket.
This is one time 'buy cry once' doesn't work. Buy a Shars set and use, abuse and wear it until you have the habits to care for a good set. The cheap set becomes your setup and shop set, and your good set is used only for specific operations. All really good tool and die shope used to follow this principle.
My mentor had the skills to machine, heat treat, and grind inserts for punch presses. He could stack 20 of them in a stack and measure the the whole tolerance was less than 2 tenths. it took him 10 years to get it that good, with 20 years already under his belt. This is the advice he gave me when I bought my first set.
