- Jan 3, 2015
- 400
How do you get a shim between the two ballnuts? In mine that dark piece in the middle wobbled around a little but I was trying my best not to let them get apart.
Bob
Bob
well that's not right, the second ballnut should be tight up against the shim.How do you get a shim between the two ballnuts? In mine that dark piece in the middle wobbled around a little but I was trying my best not to let them get apart.
Bob
I also think a better option would be to put a belville washer stack in there so that you get preload that will compensate for wear on the ballscrew.
Bob
What Jim said.
Before I took my mill apart, I don't recall actually measuring backlash, but I didn't feel any slop in the handwheels. I figured taking it apart would destroy that anyway. On the other hand, I think the gibs were farther in than they are now. I need to take a look at them in the morning. I think they may be loose.
I tested my mill on rapids and I can get 280 IPM on all three axes. Coming from a system where Z was 15 ipm and the fastest axis was about 50, it's amazing. If I gave up a little speed and improved backlash, that would be an acceptable trade.
Bob
I don't have handwheels on my mill so wasn't able to detect backlash that way. It showed up when I did a circular pocket. The hole was out-of-round about .006". I learned a valuable lesson that proper gib adjustment and warm up routine go hand-in-hand. You can't do just one and expect to get good results, at least on my machine.
I have my rapids set at 100 IPM. Tried it at 200 IPM and it looked like the machine was beating itself to death on short moves. It's what works for me.
Tom S.
