Center finding question
Awesome! It looks great! Excellent work. The channel looks perfect.
I had a plastic one, but it got demolished recently. I'll be making a copy of yours in the near future
My German shepherd was hangin out with me in the shop, and I guess he got bored. He swiped it and chewed in into 2lbs of plastic confetti before I noticed.
I've got a chunk of steel waiting for the right time, but since it's 7°f in the shop right now, I'm waiting for better weather.
@walterwoj,
Nice job. I could use one of those.
Why the recess in the back?
Is that for function or just for weight?
Thanks,
Brian
@walterwoj,
Thanks,
Brian
Mostly just because! All the commercial ones have a very deep recess, I suspect it's to make it cheaper ( they prolly start with a hollow cast blank, less steel) but I thought it might make it sit better on the bench if the bench isn't perfectly flat. My recess is only ~.250" deep (didn't have a target, just made it look good.) I think the commercial ones are at least .500" deep.
This is also the first use of my DRO's bolt hole function. turned out good.
I've had this chunk prepped and waiting for better weather. 4-5/8"x1-1/8"
It's a leftover from a D1-4 spider chuck I made awhile back.
If it turns out as good as yours did, I'll be
very happy.
OK, I give up!!
What is it, how is it used and do I need one??
Looks like a good reason to finish the fixture plate I started a year or so back!
OK, I give up!!
Its just a bench block ... you use it for punching out pins mostly. holding on to a round (a v block can too)... helping to drill straight with a hand drill.
tap straight by hand, Not necessary, less used than you think... Gun smiths may prefer a delrin version to protect the gun.
I always wanted one, then when I got one, I lost it...
Yea, prolly more a shelf tool than a useful tool but It fit my skill level and tool set, and now I not longer feel tempted to buy one. :applause 2:Win-Win!:applause 2: And now since I have one, you definitely need one! Remember: He who has the most tools wins! And now I'm ahead! :cool:
Good job. Don’t see many people making bench blocks. Here’s mine:
E19CD44C-679F-4ADF-8E92-7EC6F4535FE2.jpegIt’s 4.25 dia x 2” high. 1018 steel, case hardened, surface ground top and bottom. I sandblasted it after heat treating, then put it on the surface grinder. It’s turned a nice gray color over the years from being exposed to oil. Not my design, I borrowed one from a British tool and die maker who made his during his apprenticeship in the 1950’s. I made mine just before graduating from the machine technology program at the local community college in 1985. It’s been very useful over the years.
very happy.
Reviving this thread after 8 months, because I finally got around to turning that chunk of steel into a bench block. Inspired by some of the creations here.
I copied the Starrett 119 bench block. It has hex flats, I guess so it can be put in a vise more easily.
