- Jan 5, 2014
- 995
It has been a few minutes since anyone has brought up carbide tooling, so here goes. I'm shopping for a decent carbide insert and holder setup for my lathe. Details are below but my biggest questions are these:
What is the practical benefit of a 3/8" vs. a 1/4" or a 1/2" vs. a 3/8" inscribed-circle size insert? Cost seems to go up with size somewhat. Are the bigger hold-down screws a benefit? Other practical benefit?
How much of a practical difference might I see with an insert holder with a larger cross-section than the 1/2" ones? My tool holders can easily handle 5/8" or 3/4" but is there much benefit? (Assuming I'll probably not need to hog out industrial level amounts metal per pass.)
I have a budget of $1000-1500 to get this off the ground. (I sold some equipment and that $ has to be spent, you know, for the good of the economy.)
Thank you.
Background:
I have the same set of cheap triangular inserts and holders that came with my lathe and they have worked "ok". I've used HSS quite a bit but really like the results I get with quality carbide threading tools and parting tools. I did an internal acme thread with a carbide tool that was just excellent. It was a happy day. So I'm shopping for a basic profiling/facing setup with right-hand and left-hand holders for 80 Deg. diamond and 135 Deg. for more intricate profiling. I have a 16" lathe with a CXA tool post. My max RPM is 2000, 5 HP. I work on aluminum, various steels, and sometimes stainless.
Thank you.
Background:
