Carbide insert question
Okay, the size of a 215 insert is .250" inscribed circle. A triangle needs three sides being .433" long to contain a .25" circle.
Spilt in two so we have a hypotenuse of .433" and an opposite side of .2165". So that makes the adjacent side or the length of a 215 insert ~.375." long.
Somebody feel free to peer check me.
Excellent math:
Pardon me guys, if the hole was .313, what size would that make the length?
Do you mean the inscribed circle? An insert with an inscribed circle of .3125" would be
.460" long.
I want to really thank all of you. I kinda understand this stuff, but then something else pops up and messes it all up for me.
I'd really like to find a insert as follows:
T- triangle
P- 11 degree relief or just a little more
G- doesn't matter, less the better
H- i need a counter sink hole for cap
screw
2- would really, really like a 2.5 hole .312-.313
1- 1/16 or 1/8 would be fine
5- 5/64 radius is fine
My work bench is just full of paper trying to figure this thing out
T- triangle
screw
If by "hole" you mean the inscribed circle (I.C.), then the ANSI designation code for the insert you seek would be as follows:
TPGH2.515 for 1/16" thick
TPGH2.525 for 1/8" thick
It might exist (but I doubt it) in metric form with an ISO designation of:
TPGH100120 < the 10 is 10mm side length (equivalent to ~0.4"), the 01 is 1.59mm thickness, the 20 is 2mm radius
TPGH100320 < the 10 is 10mm side length (equivalent to ~0.4"), the 03 is 3.18mm thickness, the 20 is 2mm radius
The tightest tolerance would be an "M" and designated TPMH.
I'm not sure such a thing exists. TPGH inserts typically have an I,C. of 0.250" or 0.375". If a TPGH insert exists with an I.C. of 5/16" (0.3125"), that would be news to me. I recommend you call Carbide Depot and discuss this with them. If such an insert does exist, they will know.
That would be size of 2 so 1/4" inscribed circle.
1.5 thickness of 3/32".
0 radius which is .004"
Did you see this insert somewhere?
