- Oct 18, 2016
- 2,872
2nd Attempt:
Tonight I brazed a pin into a 1/4" steel plate as a test for a project: I'm fabricating a pin spanner that will hold my
collet chuck while I tighten the collets. This was probably more difficult than the real thing since the spanner will have
less mass around the pin. The first time I tried was a fail: didn't get the plate hot enough and the rod didn't flow
around the pin properly. The second time (below) worked fine. Preheated the parts to 450 degrees in the toaster oven and
then made sure the parts were hot enough before flowing the rod in. I used Map-pro for this one. Should be ready
for the spanner next.
