Silver soldering is a low temperature silver bearing solder, Typically less that 10% silver and solders at temperatures below 840°F (450°C).
Silver brazing is a higher temp process using a silver ally that is much higher in silver content and brazes at temperatures above 840°F (450°C).
Silver brazing is stronger than silver soldering.
Silver soldering is stronger than soft soldering.
Number 1 question that makes a huge difference, Are you talking about silver soldering or silver brazing?
Number 2 question What solder/brazing alloy do you want to use?
These are the 2 big questions as to the type of torch you will need.
Next is the size of the parts, this will determine the size of torch you will need.
