What size are you interested in? This will influence the choice of heat source.
MAAP gas is hot enough for brazing most small items or thin cross-sections ( about 2900°C)
Air- Acetylene torches burn slightly cooler than the MAAP (about 2200°C)
the torches you have referenced may mix the air/acetylene better to achieve the higher temperature.Anyways my question. They quote 2632 degC so 400-ish higher than what you referenced. Is this one of those 'it depends' type specs?
