Day 10
The build of the rest is finally complete. I wouldn't call this project difficult but it took some time (and dedication) because it does have quite a lot of parts. While I had studied it well before starting and made sure I had tools, supplies etc ahead of time to carry out the project but I realized during the project that a few handy jigs and tools would've helped even more. One of the things I want to make is a better work stop, a AXA holder for the dial indicator (for doing 2nd ops, sometimes you can't avoid this) and add air to the lathe because it works so well on the mill. A vfd on the mill would be sweet...but I need to research what motor will fit my RF30, maybe replace the spindle bearings too.
First task was to true up my 10 yr old grinding wheel which I didn't realize how irregular it was until I did this
This was very dusty work and I should have done it outside. Even with the vacuum on this accumulated on the grinder cart:
Then I attempted to sharpen an endmill...which has a learning curve to understand all the angles and such so that will take some learning and practicing...now that I have the ability to do so in my shop.
