I design and build almost exclusively in metric. Using inch sized materials or tools is not a problem, just machine to what you need, and convert where necessary. If I am doing something where the design calls for say 6mm thick stock for something where the thickness really doesn’t matter, I just use 1/4” stock and not worry about machining it to 6mm.
I have a couple metric size end mills and plan to get a few more for small slots on models where the inch sizes are not convenient, but for just about everything else, the inch size tools work just fine. I have some metric drills, but the fractional, letter and number drills are close enough to the metric sizes needed that you could get away without any metric drills in many cases.
