Some more info he wrote this morning.
Hi Richard
It will depend on thread lubrication and how hard one yanks on the wrench--to summarize (and fwd)
1). what is the force on the T nut?
Boltforce.xls | | |
To determine force from a bolt | | |
By Alex Slocum, last modified 2023.03.12 by Alex Slocum | | |
Be consistent in units (lbf in or N mm) | | |
Enter numbers in BOLD, output in RED | | |
Units: | lb in | |
Force on end of wrench | 50 | |
Length of wrench | 12 | |
Torque | 600 | |
Bolt diameter | 0.50 | |
Pitch (Lead) | 0.0769 | |
Coefficient of friction, mu | 0.2 | |
Screw pitch diameter, dscrew (mm) | 0.42 | |
Thrust bearing diameter, dthrust (mm) | 0.56 | |
Thread angle (deg), alpha (rad) | 30 | 0.524 |
Thread root stress concentration, scf | 1.5 | |
Beta | 0.182 | |
Thrust bearing efficiency, etathrust | 52% | |
Backdriveable? | NO | |
Thread efficiency, et | 20% | |
Total system efficiency, eta | 10% | |
Force, thrust | 5,077 | |
Estimated torsional stress, tau | 40,352 | |
Tensile stress, sig | 44,588 | |
Mises equivalent stress, sigma | 124,355 | |
if well lubed threads... force might be 2x, and maybe the person yanks for an impulse of force because wants to make sure no slip of the vice being bolted down:
Threads per inch (1/2-13) | 13 | |
Lever arm (in) | 12 | |
force (lb) | 100 | |
efficiency bolt thread and head | 20.0% | |
force generated (lbf) | 19,604 | |
T nut effective width | 1 | |
T nut length | 1 | 3 |
area | 1 | 3 |
stress (psi) | 19,604 | 6,535 |
Grey Cast iron yield strength (psi) | | |
low | 20,000 | |
high | 60,000 | |
this compressive force squeeze the cast iron which causes it to bulge out (Poisson affect) thereby "expanding" the cast iron around the T slot... so a number of bolts doing this in a number of different places... voila!
